Hi
My dad has just bought a new house (1930s) and we are in the process of updating it all. It's previously had a dual rcd split load board fitted at some point.
We are now having some plumbing done to replace lead pipes and fit central heating.. the plumber will replace half of the lead water main pipe running under the floor and connect a new plastic one to the kitchen.
My questions are:
Now that the main water pipe is half plastic does it still require bonding?
Is it still a requirement to cross bond pipes in the bathroom and also the central heating pipes?
If both gas and water pipes need bonding do you have to run 2x 10mm earth cables or can you use 1x cable and link them together with a bonding clamp?
Any help would be great!
My questions are:
