Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Assuming that you are talking about the impedance as measured with sine wave AC, the only mechanisms I can think of which would result in such a figure being appreciably different from resistance (measured with DC) are ones which would result in the 'DC resistance' being higher. In that sense, I don't think the DC measurements are likely to ever be "unsafely misleading" - it is much more likely that they would be 'unnecessarily pessimistic' (i.e. producing an over-estimate of earth impedance).
However, another factor to consider is that of the voltage used for testing, whether AC or DC, since the apparent impedance/resistance will probably vary, to at least some extent, according to the test voltage.
