Earth Leakage Trip Switch tripping
21 Feb 2010
Surrey
Apartment is 8 years old
Up until 2 days ago, no problem with electrics.
I have a problem now.
When I turn on the water, it turns on a pump, to pressurize the water.
This causes the "Earth Leakage Trip Switch" to trip.
The pump does not turn off, and stays on until the tap is turned off.
Whatever circuit the pump is on is not affected by the tripping earth leakage trip switch.
When the tap is off, I reset the earth leakage trip switch.....and everything works again.
I wonder what might be causing the problem ? Any educated guesses ?
View media item 31317 View media item 31318
Its the blue earth protection trip switch which is tripping.
What does "cross connection between the pump circuit and the one with the rcd" mean ?
What would cause a cross connection ? It worked for 8 years, and now its suddenly it trips the blue switch...
Could water explain the cross connection ?
