Hi folks,
I have a general query, I'm in the process of replacing all the chipboard flooring in a recent house purchase. The old flooring was a real mess, bits out here and there so I'm changing all of it.
Upstairs there is a bathroom and two small en-suite rooms, I have most of the flooring up so can see clearly all cable runs etc. I was concerned that only one 4mm earth wire runs from the consumer unit to the main bathroom where it connects to a strap on the sink cold pipe. There is no link from this to hot pipe and bath pipes. (all copper).
More concerning it appears the en-suite where I can see the pipes there is no earthing at all. All boards are up so clear access.
I'm having a Dual RCD CU fitted soon when my electrician returns from holiday.
Will he run extra earthing to the en-suites ? (I was hoping to have fitted new flooring) but I will wait for him to return if extra earthing is required.
I believe the existing 4mm in the bathroom will be getting replaced with 10mm earthing.
Thanks for any advice. I want the job done right so can wait before replacing the flooring.
Dave
Dave
