earthing
7 Mar 2014
London
Dear all,
I have noticed that one of my kitchen sockets is not earthed, I was wondering what would be a quick n easy solution,
its a metal twin metal socket with a metal back box.
any help will be greatly appreciated,
thanks
joe
I have noticed that one of my kitchen sockets is not earthed, I was wondering what would be a quick n easy solution, its a metal twin metal socket with a metal back box.
Do you mean that the metal plate of the socket (and maybe also the back box) does not appear to be earthed, or that there is no apparent earth conductor (CPC) going to the socket at all?
Kind Regards, John
how have you noticed this? what wires are available inside the socket? can you post a photo? if there is an earth wire, is it connected to the terminal on the socket?
Kind Regards, John
hi john,
there is no earth wire, thers only a live and neutral on it.
thanks
joe
hi the reason i opened the socket is thers was a small element of shock on microwave that was on that socket
cheers
joe
there is no earth wire, only live n nuetral
cheers
joe
I was getting shock on the microwave on that socket, hence opened it, there is no earth only live n neutral
cheers
jo
If this is a socket outlet it must be earthed!
Isolate the circuit, prove circuit is dead by using approved voltage indicator and check that the earth has not become loose or if there is one within the sheath of the cable.
If not you require an electrician.
Kind Regards, John
hi john,
there is no earth wire, the reason I opened up the socket, as i was getting a small shock on micorwave on that socket,
many thanks
joe
hi there,
there is no earth wire on it, only live n neural,
cheers
joe
