Had some bespoke iron gates made in the past attached to a brick/mortar pillar.
To cut a long story short an idiot backed into the post and knocked it down.
I've built a new pillar but it's 5mm offset from the original leaving me with gates that won't close (overlap by 5mm only).
The hinges are welded onto a 1500mm strip of steel (which gets bolted to the pillar in 5 places to spread the weight).
How easy would it be to dig 5mm x 40mm x 1500mm into the pillar?
Angle Grinder? If so, what kind of wheel?
Many thanks,
Rob.
Many thanks,
Rob.
