Easiest way of creating a 5mm deep channel in a brick pillar
3 Jul 2005
Hampshire
Had some bespoke iron gates made in the past attached to a brick/mortar pillar.
To cut a long story short an idiot backed into the post and knocked it down.
I've built a new pillar but it's 5mm offset from the original leaving me with gates that won't close (overlap by 5mm only).
The hinges are welded onto a 1500mm strip of steel (which gets bolted to the pillar in 5 places to spread the weight).
How easy would it be to dig 5mm x 40mm x 1500mm into the pillar?
Angle Grinder? If so, what kind of wheel?
Many thanks,
Rob.
Many thanks,
Rob.
surely the idiot is the bloke who re-built the pillar 5mm too narrow? :lol:
Be fair... it might be the same idiot who backed into the old one :wink:
Very helpful?
I've got 4 options as far as I can see:
1. Knock the pillar down and re-build (~20 courses);
2. Angle grind 5mm out to recess the bracket housing the hinges;
3. Use an SDS drill & routing bit to take 5mm out;
4. Re-fabricate the bracket housing the hinges.
I'm just looking for some helpful advice on which method is going to be the easiest.
I can do 1-3 myself, but would need to have 4 done by someone else.
there are various tools used by electricians to cut a Chase into a wall to run a cable along (they make a tremendous amount of dust when used inside). Expensive to buy but your local hire shop may have something suitable. It might be good because it will cut a good straight groove.
http://www.screwfix.com/app/sfd/cat/pro.jsp?id=20295&ts=30816
This little thing fits on a drill but looks a bit weedy to me.
http://www.screwfix.com/app/sfd/cat/pro.jsp?id=11900&ts=30816
Without a special tool it is possible to make a chase quickly by running an angle grinder down to make 2 slots, then chiselling out the gap. This works best in plaster of lightweight blocks. 5mm is unusually shallow, though.
Sorry, :oops: some of us like a bit of a laugh in the evening :lol: .
Being an engineer, I would take option 4 & mod the gate. Cutting a recess in the brick pier is always going to make the job look a pig’s ear!
i think scrabbling the bricks seems like a good idea, but it may have later consequences.
you will not only be taking the protective face off the brick, but be weakening it too. this is not a good idea where strength is at a premium for supporting the heavy gates.
