This morning found that water was leaking from my Vailant Ecofit 830 Boiler checked around the main connectiosn all seems okay it seems to be leaking from the inside of the boiler itself, i opened the cover just to take a look and looks like the leak is coming from somewhere around the back!
Some videos i took
When i checked the Display the pressure was really low below the dotted lines, so though i would just up the pressure a bit and after that started leaking more water kept coming out for about and hour or two but for now looks like it has stopped and the boiler is switched off now
Anyone ever seen this before?
It does very much look like water is coming from that black bit in front not sure what its called...but cant really tell for sure!
As its Xmas today hard getting hold of anyone! I'll ring around tomorrow may get hold of Vaillant directly or see if anyone local is available to come over asap to fix it
Without hot water at the moment!
Some videos i took
