Apologises for the repost of this message - this is my first time to such a forum.
I have a house which appears to have had economy 7 at one time but now has Gas heating instead. The electrical distribution panel looks a bit of a mess with 2 old fuse boxes with real fuses and an old economy 7 mechanical time switch.
I would like to replace with MCB's and also remove the rattly monster switch as it currently does not switch on any heaters, and takes up space
My electricity meter (a Siemens S2AS 100) has a the usual L and N in and L and N out. It also has a single wire that goes to the Economy 7 switch. I am worried that this wire signals to the meter that the economy period is reached and that the metering rate should change. I would be surprised if this was the case as the meter is digital and timewise should have a more accurate clock than the mechanical unit.
Obviously if this the time switch changes the rate over then I cannot remove the switch as I will be stuck on one rate which would either work out very expensive or illegal (and thus expensive).
Any ideas?
Any ideas?
