Hi all -
I've discovered a leak at the point were the ceramic toilet waste pan connects to the waste pipe. I have to admit I have noticed it a little over the last week or two, but it was only drip-drip so I placed a bowl underneath the waste pipe. Tonight the situation appeared to deteriorate somewhat, because when I flushed the toilet more came out of the connector. I'm aiming to tackle this tomorrow, but how do you remove the connector from the pan, as it all seems such a tight fit.
The toilet itself is screwed to a wooden base, this over time as rotted a little and the screws have come loose, hence the toilet is not rock solid stable as it was before so it moves slightly when addressed. I think it's this movement which has caused the leak. So i'm at a loss if I also need to take the toilet off the slightly rotting wooden base and position in a new one? If I have to remove the toilet how will I know I can replace it in the best position it was before being removed?
Thanks for any assistance you can provide me, i'm not very DIY skilled but am willing to take guidance if you can help me
Cheers
Cheers
