Having finally got my old strimmer working, I now have the problem that the line is tangled inside the line head/spool reel and won't feed out. Grrrr!
Unfortunately, although I can easily unscrew the head from the spindle, I can't find any way of opening it up!
On the back of the body, there's a female left-handed threaded hole which screws onto the spindle.
On the front/bottom there is a square steel shaft set flush with a small plastic cap. Under this small cap is the main reel cap, which is set into the body and spring loaded, so it can be depressed easily (I think this is how line is meant to feed out in use, by tapping it on the ground).
There appear to be no screws or other fixings, although on the back of the body are four small square-ish holes near the edge.
The cap rotates slightly in the body shell, but no more than a fraction of a turn.
If anyone has one of these and can help, I'll b hugely grateful as it's driving me nuts, and the weeds are just laughing at me on the allotment!
