i need help! i have a fusion electric boiler which heats up central heating and hot water. the pump is running all the time even when the programmer is not calling for heat. when i turn off the boiler from the switch on the boiler cover the pump stops, but when i turn back on and call for heat the pump doesn't start, but when i turn the boiler off and on using the 45amp isolater switch, the pump runs continously. also when the two motorised valves are closed, the front panel tells me the flow rate is insufficient. are the two problems related? anyone out there got any advice. x
