Electric connections advice please
19 Apr 2003
Hi all..... have fitted switch bottom stairs with 3 wire... red to com yellow l1 and blue l2 ....switch top stairs needed to work and have connected 3 wire as down stairs..problem is how do i connect main feed at top switch also lights at this switch too so as to enable both switches to operate lights....is it possible ?thank you all
from your existing light you should have two wires (one live the other is the switch wire) you connect these to L1 & L2 . doesnt matter which way round.
see this
Thank you Breezer,that helps a lot,i get the idea now,,this is a new project with all new wiring....thanks
Thank you Breezer,this is a new project with all new wiring,,,no old wires
