Electric Convector Heater - Heat settings -Thermostat
Status
Not open for further replies.
15 Nov 2018
I have two 2000w free standing electric heaters, one in living, other in bedroom.
Despite having a built in rotary control to adjust heat settings, described as a thermostat, I’ve only recently noticed that the heat settings, have no bearing to the room temperature reached ?
I normally select heat setting 3, believing that once the temperature reached, the heater switches off and remains off, until the room temperature drops, and then, the heater will automatically switch back on, until desired temperature of the room, associated with heat settings 3, is reached !
Although, the heaters “thermostat,” appears to operate like a timer, rather than responding to room temperature.
I assume, the heater producing heat, every few minutes, then switching off for 5 mins, then on again, continuously, regardless of room temperature, is far more expensive, than remaining off until the room temperature has dropped below a specific level.
Both heaters are operating the same; also I’m curious as to whether this is normal operation for this type of heater, especially when described as a “thermostat” heat settings/control.
Similar to this:
They are cheap for a reason. I think you are expecting them to be a bit too sophisticated. Do they ever heat the rooms to a comfortable temperature.
I’m only expecting the description of product, such “Adjustable thermostat control with easy-to-use dial, which was similar in description to my heaters when bought, which I bought, rather than the less expensive model. that didn’t have thermostat control;
My heaters was significantly more expensive when bought.
Absolutely normal, you could use a plug thermostat or some other controls if you need something more sophisticated.
Yeah, I was thinking of using a plug in thermostats, although one would expect a plug in thermostat to detect the room temperature and isolate power to heater when the actual and desired room temperature is reached !
Anyone know of a smart plug with a separate Thermostat, that can be affixed to the wall, which can communicate with the smart plug via Bluetooth or its own WiFi network, without the need for WiFi home broadband and without the need of a mobile app ?
Do they ever heat the rooms to a comfortable temperature?
Yes, although now I’ve discovered how the heat settings actually operate, I’ll prefer to control the heaters by a heat detecting thermostat, rather than the built in faux thermostat.
If they heat the rooms to a comfortable temperature, what more do you hope to gain?
Because the built in thermostat, doesn’t appear to be a thermostat, it keeps cycling the heat on and off regardless of the room temperature, which I’ve only recently discovered.
I would much prefer the heater to warn the room to a comfortable temperature, then switch off when reached, and remain off, for how ever long it takes. for the room temperature to drop to a specific temperature.
If you try adjusting the knob in the light of experience, it will probably keep the room at a comfortable temperature.
Which is what the heater is for.
What do you think I’m using the heater for, one in my living room, other in my bedroom !
The heater’s heat settings do not respond to room temperature and it appears the heat setting operates via a timer rather than temperature.
You can't get a heater with a built in thermostat to control the room temp. just the temp. of the appliance. Even with an external room stat. it will still switch on and off according to the temp of the appliance. You seem to be expecting too much from a cheap little heater.
Status
