Hello, a bit of a green question here. My hedgecutter's cord was severed. And so bought one of those connecters that allows you to connect the severed wires safely. By feeding in the wires like you do in a plug. The connecter says it runs on 250 V and 5 amps. Where as the hedgecutter runs on 230v and 50 hz. It says nothing abount amps. Should the hedge cutter still work using this type of connector? because I've tried wiring it all together, and still no luck, I definitely connected it properly. Also, does the electricity on your average house socket, run on AC? Thanks in advance.
