If your lighting worked perfectly and then you changed a switch and now the lighting is no longer working perfectly, then it is something you've connected up wrong. Pictures, please.
Do not rely on a neon screwdriver to test live cables.They will light up with only a few volts and if live it is only a resistor stopping the current from 240V being driven through you!!
