I have a similar issue
My Hob says it must be wired via a DPDT to 6mm T&E, the oven only seems to require a flex connection to a socket (2700w)
Would it be acceptable to plug the oven into the cooker/Hob socket outlet?
Or to the existing (old) House Ring main, which will obviously have many other appliances attached?
