- Joined
- 20 Apr 2014
- Messages
- 2,467
- Reaction score
- 0
- Country
I've bought an electric hob and oven from B&Q which I need to wire in. Having read the posts on this site I'm going to use 6mm twin and earth to wire in the hob from the cooker point and then use 2.5mm 3 core butyl insulated cable to take a feed from the hob to the oven. Is this the correct way to wire it? Also, the metal casing on the oven has a earth symbol stamped on the casing with a hole next to it. Does this mean I have to run connect the casing to earth as well as connecting the connection terminal to earth? Comments would be appreciated.
