Can someone tell me correct way to connect electric oven.Oven, s 3 killowats.Cable run from CPU is about 7 meters.book says Min cable size 2.5 and fuse size Min 15 amp-20 amp MAX.double pole switch is also mentioned.Is 2.5 cable from CPU to switch suffitient.What size round flex?Cable would run from 20 amp mcb as radial.Kitchen is fully fitted so it is imposible to fit cooker switch above work serfaces,it has to be behind adjoining cabinet.does it matter?
Thank you.
Thank you.
