Hi All,
basically I live in Estonia, I have oil fried central heating, but oil has somewhat doubled in price since last year so the minimum order of 1500 litres which heats my house for 4 to 5 months of the year is now almost €1500. I am currently selling my house (or trying at least) so it doesn't make sense to shell out such money if I manage to sell the house in a month or two.
Obviously in Estonia in winter, temperatures in Dec and Jan can be as low as minus 30, which even for the oil fired central heating is a tough job to cope with. The house is breezeblock built with cheap big windows, poor insulation and in all honesty when it is 0 degrees outside, it's about 12 degrees inside without the heating on - not much fun. But I need to heat somehow and I am considering panel heaters or fan heaters and I would like to figure out what would be most cost efficient and also what will heat to a decent livable temperature. Buying electric heaters is cheaper in the short term and hopefully if I am not spending €300 on heating bills every month then it should be ok.
I have 5 rooms; 7m2 (bathroom), 8m2 (Kid's bedroom), 11m2 (kitchen), 20m2 (lounge) and 34m2 (bedroom). The kitchen and lounge are open plan. according to info on the web, I should be installing 750w, 750w, 1000w, 1500w, 2000w heaters respectively.
1. Isn't this going to use a lot of electricity?
2. Is it better to take say two 3.3kw heaters and move them around as needed? Or do they use far more electric than these panel heaters?
3. If I use panel heaters, I read that they should be on all the time at a low temperature in order to be more efficient rather than coming on and off with a timer when required - is this correct?
Your input & help is appreciated.
Tony.
Tony.
