havent bought shower unit yet,and yes cold only,just wasnt sure if pump pressure would allow sufficent time for water to be heated by elec shower unit ,
thanks
Why not buy a pumped electric shower, Mira Excell or Triton. Easier than fitting a pump. You usually have to wire into the shower so the pump activates when you turn on the shower flow. Purpose made is better.
yes i see your point,
i think i will fit a termostatic mixer with a pump fitted at base of hw cylinder,cw tank is ok 50gallon,and leave the electric/power shower alone.
thanks for the help.
