Electric shower Tripping off when not in use
15 Mar 2004
Hi, My electric shower keeps tripping off when its not being used. It works perfectly fine, but twice over the last couple of weeks it trips off at some stage during the day when its not in use?
Should I get it checked?
Thanks in advance for any advice
Its only about 2 years old and has its own unit (RCD?) which has a master switch and a "Shower Supply" switch which is the one that keeps tripping off, the master stays on.
What markings are written on the part that switches off, and what markings are written on the part that stays on?
As Aragorn says a photo would be nice ..or at least what is written on the 2 items
True - but since we're told that it's not the RCCB which is tripping, it presumably must be an MCB. If that's the case, and given that the shower is working and nothing dramatic is happening, it's very difficult to see that the cause could be anything other than a faulty MCB, which just 'trips' spontaneously.
Kind Regards, John
Kind Regards, John
Thanks John, so as long as the unit works do you reckon its safe to leave it?
View media item 75059unit similar to above
I wouldn't go that far - from afar, I can but speculate about what is probably the problem, so you definitely need to get it checked out and sorted out - since I could be wrong. In any event, if my suspicion is right, it's probably only a matter of time before the MCB gives up the ghost completely, in which case you won't be able to use the shower at all.
Do I take it that its the thing on the right of your (tiny!) picture that is tripping. Does it have something like B40 or B45 written on it?
Kind Regards, John
yes the switch on the right trips and it has B40 written on it
Right - as I had presumed. My belief remains that the B40 device itself is easily the most likely cause of the problem - but, as I said, you really ought to get it checked out, not the least in case I'm wrong and something more nasty is going on! As I'm sure you'll understand, without being there, I obviously can't be sure about anything.
Kind Regards, John
