Electric showers
16 Aug 2011
Cheshire
Can anyone recommend an electric shower, exsisting shower seems to have a broken thermostat as only geting cold water. I have a combi boiler, but as electric showers use the cold water feed does this even make a difference? Preferably easy for DIY'ers to install using exsisting plumbing/wiring.
Current shower is a Aqualisa Quartz electric 8.5
Current boiler is a Worcester 24cdi
It could be that the heater can has simply failed. Or the thermal cut-out - have you checked that?
But having a thermostat is a good point - most electric showers just have a crude anti-scald system, so when someone turns on a tap or flushes the loo the shower goes very hot, and won't cut off much before it gets to the point where it'll actually injure you.
Some have proper thermostatic controls.
[code:1] I have a combi boiler, but as electric showers use the cold water feed does this even make a difference? [/code:1]
No - you can't supply an electric shower from a combi.
You might be able to supply a mixer one though.
Give thanks to the DIY gods if you manage to find a shower with the water and electrical inlets in the same places as the current one.
8.5kW isn't very powerful.
What rating is the fuse/MCB, and what size is the cable, how long is it, and dose it go through any insulation?
Does the circuit have an RCD?
Could you considor ditching the electric shower and having hot water supplied from combi boiler? It really might be cheaper than having a decent electric shower fitted SAFELY and to current regulations.
I agree - and if you can train anyone else in the house to leave the hot taps alone when you in the shower (easier said than done!), the shower will be much better than than an electric one.
nurseylou, please dont make duplicate posts for the same purpose. Mods please delete her post in central heating.
You are mroe likely to get a reasonable response here. The plumbers get a bit antsy about DIY work. :rolleyes:
Get a thermostatic one. It will adjust constantly to give the right temperature.
