Hi
I am not being stingy (a glove box stuffed full of selco/screwfix/tool station receipts can prove that) however I don't like buying things that are a bit of con (e.g. those reflective panels behind radiators!) and I have always been curious about these thermal tiles so I would like someone do give me a definitive answer about these things please.
I am about to lay an electric UFH cable mat (ground floor lounge) and wondered if I really need thermal insulation boards. Are there any physicists/engineers here who understand heat conductivity etc to the level of maths equations?! My gut feeling tells me these thermal boards would probably have a positive effect but by how much is the question? Negligible amount? I know lots of people sell them but then snake oil also used to be popular years ago!
I have had the timber floor up and installed RW6 Rockwool slab (the highest density one they do) between the floor joists which was left over from another project. I friction fitted them and used expanding foam here and there to get a very good seal. Underneath that I laid loads of loft insulation on a roll while leaving enough room for air to circulate around the joists.
On top of the joists in 28mm quietboard T&G chipboard (which has the foam backing). On top of the this I will lay 5mm SLC and bed in the electric cable mat. And top of this will be 20mm engineered oak planks.
Sorry for all the detail but I though I might as well write it all.
So, I don't have a massive concrete slab of un-insulated floor, so would it be worth me fitting 10mm of thermal insulated boards?
Cheers for any advice
