Electric v gas boiler
27 Mar 2022
Hi guys i recently joined this forum.
i had an elektra 12c boiler installed in 2017 (electric) however we are contemplating if we should change it to a a bax gas boiler (30kw) to save on our bills. Will this be worth doing ?
Thanks guys!
Energy from electricity costs about four times as much as energy from gas, so of course your running bills will be lower.
Installing a gas boiler is not a DIY job and it would not be a good move to buy one from a DIY shed. Ask around for personal recommendations of a local registered gas installer.
An advertising website, where people pay to be listed, is not a personal recommendation.
Had 4 come over all said a 30kw is sufficient for our house.
Not every household requires the same?
30kwh is enough to heat a small school and is most likely grosely oversized. What matters is the actual heat loss for you property and selecting a boiler that can modulate down to the demand at a system flow temperature that is actually efficient.
Noone you have had around has any interest in giving you a system where running costs are minimised.
do you currently have a hot-water cylinder? What colour?
Are you satisfied with the flow of water from the hot tap?
how many litres per minute does it deliver?
My three story house has a 20 kW oil boiler which cycles on/off so clearly larger than required. Every time a boiler switches off any heat in the boiler either goes out of the flue, or with some like my C Plan it can heat domestic hot water if not already hot, but basic idea is for it to switch off as little as possible.
Oil boilers don't modulate, they only turn on/off, a combi oil boiler just has a tank inside the boiler, gas however can modulate, typical is 6 - 26 kW, but the higher to maximum output also in general the higher the minimum output, there is a tendency to use a larger boiler to give a good output for domestic hot water, but can't see why, before the combination boiler I had two independent boilers one for central heating and one for domestic hot water, the latter was a Main 7, seem to remember maximum output was 18 kW I know when I decided to install a shower it was no large enough to have a shower with side jets, but for the standard shower I had to be careful to have a shower head large enough as if it didn't use enough hot water the boiler would cycle off/on, not what you want in a shower.
Mother had a combi boiler and it had two options, eco on or eco off, with eco off there was a small reservoir of hot water, but in the shower the reservoir would run out, so shower would go warm, cold, warm again. But with eco on this did not happen, once warm stayed warm, but if sink taps not turned on full would not get hot water.
This is all hinged around boiler minimum output, boilers can be too big.
Also radiator temperature, with oil is does not matter, but with condensing gas whole idea is the return water is cool enough to extract latent heat from the flue gases, so each radiator is set with a temperature gradient so return water is cool enough, so whole radiator is not at 70°C likely at 55°C at the return end, this is also required for the TRV to work well, as my TRV's when they exercise to stop them sticking, take around 3.5 minutes to go through the cycle, if the lock shield is not set, the radiator can get stinking hot before the TRV can close.
Last house when bought late 70's had no central heating, open plan, and whole house (three bedroom) was heated with a 4.5 kW gas fire vented with a flue brick, at this time no cavity wall insulation and no double glazing, the big problem was no automated control, so latter did fit central heating, but a 4.5 kW gas fire heated whole house, kitchen was a little on cool side, but it worked, which gives you a good idea how large a heater is required.
Having a larger heater allows for faster recovery, essential if using geofencing, whole idea is not to heat home when not in use, but if your living room radiator is 6 kW and your using electronic TRV heads so only heating rooms in use, then you need boiler to turn down to 6 kW.
Even with timed switch on, I have sequence, kitchen, dinning room, living room then bedrooms, so on switch on all boiler output going to kitchen, there is no need for a massive output boiler today. Minimum output has become more important than maximum output.
Thanks guys!
Why a Baxi gas boiler specifically? There are much better boilers out there. Yes, almost certainly a worthwhile conversion but make sure you get a good installer who understands how to get the best efficiency out of your new boiler. It's not just a case of throwing them on the wall and turning them on, they need more setup than that
guess the principle of how a combi works is lost on you then !
OP
if you are being offered a 30kw baxi 630 combi they are a great little boiler and very reliable and all brass inside unlike some of the so called premium boilers that are full of plastic
OP
But crap modulation, hardly any options for setting it up for the system - can't even adjust the pump speed - and the OpenTherm doesn't work properly
