Electric Wall Hung Fire with more than 2KW heat output
4 Oct 2010
London
I am looking to buy an electric wall hung fire.
The problem I have is that it will be the main (only) source of heat in the room and most don't seem to generate much heat
I have calculated the area in the room and i need a fire with 3KW of heat to be able to heat the room.
Most fires i have seen only go up to 2KW. Does anyone know of any that have 3KW or more?
No something like this
[http://www.homebase.co.uk/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=20001&partNumber=1658248&c_3=3|cat_14289968|Wall+mounted+fires|14289971&c_2=2|cat_16849264|Fires+%26amp;+surrounds|14289968&c_1=1|category_root|Heating+and+Cooling|16849264][/url]
You may have to have more than one unit in the room a 3 kw source may not be enough during really cold spells , an additional convector panel heater on the other side of the room would prove more efficient and give less cold spots.
