I want to connect the new cooker to the 30A switch across the kitchen ahead of replacing the kitchen. Question is can I run the 6mm heat resistant flex around the kitchen under the cupbords (approx 8m) on the floor or should I use some flex conduit.
When the kitchen is replaced I will run conduit under the floor and across the kitchen. This will be a temp solution for couple of months.
