electrical
13 May 2010
Florida
I want to connect an outdoors hanging lantern to my recess lighting on my porch.Do i need any special materials or electrical connection besides the usual hardware ,to do this job?
Is this a UK installation or a USA, as different regulation may need to be complied to.
If USA post on the forum headed electrics outside of UK.
If UK the connection can be made using 1.00mm cable, if the cable goes directly into fitting, with no connection elsewhere on the outside wall you should be okay, a separate functional switch arrangement would be advised.
Also RCD protection, if not already supplied to the lighting circuit.
