i put my hand in my pond and got a tingle [250mV dc] the only electrics on the pond is a live cable going to another pond
has anyone got an explantion for this
i have a multi meter and i put the two probes in the water about 25mm apart i put it on ac as well but didnt get a reading
Well, apparently the meter read nothing, so --- no. It seems [250mV dc] was a random guess... not a measurement.maybe an electrochemical reaction between the multimeter probes?
show is an electric citron, but in the main it needs power from some thing a bit bigger to feel it. Around 24 volt is where you start to feel it, a wagon covered with salt and grit has given me a tingle.Taking posts #1 and #3 together, I thought he meant that he got a reading of 250 mV with the meter on a DC range but 'nothing' on an AC range ?Well, apparently the meter read nothing, so --- no. It seems [250mV dc] was a random guess... not a measurement.
I'm not suggesting that this is what the OP is observing, but one can get a potential difference between two points in a mass of water just as between two points in a conductor of non-zero resistance/impedance.I am not an electrician but if you put both probes in to the same pool of water, surely you shouldn't get a reading?
Yes, that makes more sense.Taking posts #1 and #3 together, I thought he meant that he got a reading of 250 mV with the meter on a DC range but 'nothing' on an AC range ?
Kind Regards, John
Indeed - and that's why there are particularly demanding regulations in situations in which 'livestock' may be walking about. Without specific precautions, under certain fault situations, it's not impossible that a dangerous (potentially fatal) potential difference can arise between the front and back 'feet' (hooves etc.) of horses and cattle etc.Wow John, never considered horses etc. Yes with a human’s gate, you may not feel it, esp with rubber soles. It sounds terrifying either way.
As has been said, I think the first things you should do are:Here’s a thought, as we still haven’t fully ascertained the AC/DC aspect, meter range etc, what about this…
