Hello everyone
I'm trying to extend electricity to my shed , currently I use an extension lead when I use it and wind it away after each use. I can't justify the cost involved with getting a electrician do the job considering this is for occasional use right now and we could move houses in a year.
From what I read the moment I get a fixed SWA involved the system need to be notified and building regs get involved.
Shed is wired up with couple of sockets and a LED light via a 5A FCU
Can someone please confirm if any of below methods would get me around the regulations and at the same time keep me safe and right side of the law?
1. Use a caravan type extension lead (2.5mm) with appropriate connector at the shed and other end plugged in to an outside socket in my house, extension lead to be removed after each use.
2. Use a normal extension lead (2.5mm) plugged in to an outside socket in my house, shed electrical system fed with a 3 pin plug which is plugged in to the extension lead, basically the whole shed is wired to the back of a plug which gets plugged in to an extension lead, extension lead to be removed after each use.
Outside socket of the house is on a RCD.
I intend to use power tools inside the shed includes angle grinder, mitre saw, bench drill and a 160A mig welder.
I'm confident of carrying out DIY electrical work in a safe manner.
Thanks very much
Thanks very much
