Electricity usage was 6kwh now 46kwh per day
Just make sure that you keep your usage down for a couple of quarters after the new meter is fitted - then you can show that the old one was clearly over-reading even when it appeared to be OK :wink:
I fhte supplier is 'difficult' about it, point out to them that there are strict rules on meter accuracy, and if they try and charge you for the 'excess' usage their faulty meter has clocked up then you'll consider reporting it as fraud.
I understand they base past useage on a 7 days use with the new meter, so far, i seem to be using around 10kwh a day, if that averages over 7 days, its been wrong for some time, so should be in for a big refund.
even still, i shall be a bit careful with what I use when the new meter goes in for a while!
