Thanks again guys,
Just to clarify a few things.
Firstly - yes the electrician did know that the sockets were redudant and were going to be plastered over.
Secondandly you were asking whether it was an earth fauly and if the kitchen circuit was a MCB or RCBO, my answer is I don't know sorry, I don't know much about electrics! All I know if my fusebox has a big red siwtch which cuts the whole power and then a smaller grey switch in the middle, - it was this switch that kept tripping out.
Also getting under the floor wasnt really an option, because the cables seem to be fed from the upstairs bedroom, this would of meant moving furniture and ripping carpets and floor boards up, - also I was running out of time, I needed all of this ready as the joiner is booked for this morning to come and fit my new kitchen!
Anyway, the electrician came back last night and I confronted him about this and he said if they are taped over then it shouldnt be a problem, he said he and others had done it in the past! I said I was not happy with this and asked him to fit a blanking plate which he did. Can any of you clarify how this is different from just having the cables plastered over? I mean the cables are still there live taped over, just sat behind a box rather than in the plaster.
Finally I found that I had a swtich in the kitchen that had a fuse next to it and a red light. We never switched it on in the past and everything worked, - my first thought was that it was for hot water or something, but that was taken care of by my central heating. Anyway after checking with a few people it did turn out to be for the immersion tank, aparently it will heat my hot water if I need it to instead of the central heating. I took the socket off and threw it as it was damaged and now I need another, but after going to B&Q this morning I could only find a swtich with a 13amp fuse but no red light (this was in chrome to match the other new sockets) so I bought that. My question is does it need to have a red light? Surely if I know which was is 'on' and 'off' I can just leave it in the off position. Also by the hot water tank is another on / off switch, surely I can just flick this off so I know I am never going to accidently be heating my water by electric rather than the central heating?
Phew hope all this makes sense and thanks for all your replies!
