I am about to erect a log cabin in my garden, the log cabin will reside next door to a detached garage that has a consumer unit containing 2 MCB's which supply the lights and power in the garage.
What I'd like to do is replace this CU with a larger one and have power for the log cabin's light's, ring main and under floor heating on this CU.
As this cabling would have to leave the CU, go outside (probably underground) and then back inside the log cabin do I need to use special cabling or can I bury the 2.5 mm t&e?
I'm aware that all this work would need to be part p certified and I will probably discuss with a sparky at some point I was just hoping someone could clear this issue up for me in advance of these discussions?
Thanks.
Thanks.
