I'm looking to buy a replacement Touch Control Pad for the above, any ideas what the part number is please? I've found one on BuySpares but it's £270! Hoping I can find one cheaper but no idea of the part number
I had a similar problem after 3 years - random operations, and then two touch pads failed completely, one was the on/off switch. Quoted price for spare was around £200. The touch panel is a glass plate with two small PCBs attached with sensors monted on them. The plate is glued on the front with adhesive strips top and bottom. Nothing venture/nothing win. I cut through the top glue strip with a stanley knife. The panel then folded down (the glue is very rubbery) and I supported it with a couple of sticky tape straps. The panel connectors were then quite visible, and they can be pulled out carefully and cleaned. To avoid static damage touch fingers and any tools onto the metal frame before touching the electronic parts. The sensor chips looked to have acquired quite a bit of dust around them, so I cleaned all around them with a small brush moistened with lighter fluid - the only solvent I had handy. Lo and behold it started working perfectly again. I cleared away the old glue strip and stuck the panel back with a few short pieces of double sided as used to mount car trims. This left some gaps at the top which I closed with a strip of transparent tape. The really annoying thing is that the panel cannot cost more than a few pounds to make, but to replace it costs nearly as much as a new oven.
