Hi
I have the above integrated fridge freezer. The freezer compartment works fine but I am experiencing problems with the fridge temperature. It is currently set on number 6 and is round abouts 10 degrees and does not get any cooler. I have read that the temperature should be quite abit less than this and especially as I am having to put it on 'number 6' which is full belt so to speak.
The compressor seems to be working as I can hear it operating so I presume this is a thermostat problem. Can you simply replace the thermostat on this model?
Has anyone got any other suggestions as to what the problem could be?
