Electromate 2000
21 Jan 2011
Dorset
Can anyone help - we have an electromate 2000 boiler that has no hot water the pump and heating exchange have been replaced as has the pcb board and still not working. Gledhill will not come out does anyone know an engineer who specialises in these boilers or can help in anyway in Bournemouth area. Thanks
have a read through here as you know whats been changed and how the system is performing.
ELECTRAMATE
You're a Star!!, thanks ever so much for this I will have a read through and if there is anything else wrong I will give you a call and see if you fancy a trip to Bournemouth. Thanks again.
ELECTRAMATE
Hi Seco, thanks for your help so far. But I've read through the stuff you mentioned and we seem to have now run out of ideas. We have changed the heating exchange, thermostat, pump and PCb board. When the plumber fitted the new pump it did start working and he advised us to leave it overnight, which we did but when checking it in the morning it had tripped out again. The electrician then changed the PCB board and as soon as he turned the boiler back on it tripped out again. Any suggestions????? Please.
