Hello ladies and gents,
I've been draughted by my sister to install a fence across the bottom of their garden but there's two elements that I'm unsure on.
I'll be installing a post in direct(ish) contact with the neighbours fence which runs further away from the property than on our side.
This run with go 6mtr then I need to change direction by about 30 degrees to run another 2.1Mtr and meet the outside of a 90degree corner post (again concrete). How do I make a 30 degree corner if it's possible with one post (or butting two together at an angle but that sounds a bit ugly) and how do I terminate against an existing post considering there'll most likely be a lump of concrete under the ground stopping me installing another against it?
*If the 30degree corner is an issue I can run straight and make it a 90 to run back to the existing post mentioned but I'll have to get creative around a big tree...
Sorry for my horrible explanation and thanks for any advice
Rob
Rob
