Escort van gearbox problems
7 Jul 2007
Sheffield
My P reg escort van seems to be developing a problem with the gearbox.
Selecting 1st or Reverse is difficult and sometimes cannot be done at all if i'm trying to park the van and need to select the 1st/Reverse several times in a row. When the engine is stopped there is absloutely no resistance at all and I can select any gear fine!
The other gears are slightly more difficult to get into than they were but this problem has had very little effect on them.
Anyone any ideas if its looking like something bad?!!
Sounds like it could be the clutch rather than gearbox.
If you look on the clutch pedal (near the top) there is a long allen head bolt which is used to adjust the cable. Tighten it a few turns and see if it's better / worse
