Eurosec Alarm
7 Feb 2020
Hi all. Have just moved into a new house, persimmon built 12 yrs old. Faced with an alarm which old owner has never used or set, and did not save manual as didnt ever use. He has suggested we contact manufacturer or builder as code to set alarm will be whatever the default code it came with.......does anyone know what this could be, plus maybe know where to download a manual from. I have googled eurosec but not showing any manufacturer info.
PR5208 rev1.0 is on base of unit. See photo.
Any help would be much appreciated. Thank you.
User default 5678 if not been changed by installer.
If code list then you will need to default control panel to reset user code.
Thanks, but how do i do that...i am not teccie and am of the point and press generation.....what do i press?
Is it reset, followed by 5678?......and will alarm go off if wrong?....have just moved in to very quiet area, so dont want to upset neighbours this early!
5678 full will set alarm if that is the code.
If it is not the code then nothing will happen,but DO NOT keep trying different code numbers as this will cause a keypad tamper fault and set off the internal sounder.
Ok lets assume 5678 set worked. When i come back inside, what do i press to prevent alarm sounding .....presumably 5678 and ? what button.
And how do i change this to one of my own? Sparkymarka above pointed me towards CP8L but is this the link to the manual i need?
Sorry to be so needy and ignorant but never used before so no real idea .
Thanks for sticking with me.
Yes
Code number will turn off system
The keypad lid tell you how to set and unset set system
