EV CHARGING AND FUSE
1 Brick = 7 pounds + 1/2 Brick.
x 2 therefore
2 bricks = 14 pounds plus 1 brick
remove one brick each side gives you 1 brick = 14 pounds.
1.5 bricks = 21 pounds.
Can't imagine how 15¾ can be arrived at...
Me neither but I know quite a few got 10.5 for some reason.
Once you suggest putting 1 brick on balancing scales and half a brick plus 7 pounds on the opposite pan of the weighing scales they tend to work it out eventually.
Or just envisaging 1 brick and 2 half-bricks, and call one of the half bricks "7lb"...
I've made it 21 since a few seconds after I wrote down x=7+x/2.
My instant reaction was the 21lb but eventually I wondered what the catch is and came up with the others.
Being deliberately obtuse with reading the question I was also able to come up with 5&5/8lb.
Edit and of course is it was read or heard as: If a brick weighs 7 pounds with half a brick, then a brick and a half weighs 7 pounds as that is the question
Some might even use the term for great slabs of stone used to build the Great Pyramid which I think were mostly about 2 to 19 tons.
Most (about 2 million, I think) were "only" 2½ tons, but others were heavier. Total mass, they reckon, was about 6 million tons. I say was, as all the limestone cladding got "recycled" in later years. It was also nearly 150m high, and it was almost 4,500 years before we built a taller stone building.
It took 30 years to build. HS2 will take longer than that, unless they (and I so hope they do) pull the plug on it.
x 2 therefore
I thought it was easier to to say that "7 pounds plus half a brick" means that half a brick weighs 7 pounds. (slap a brick on the table, chisel it in half, point to one half and say "7 pounds" and point to the other half and say "half a brick")
This one's easier to reason; ultimately you concluded a brick weighs 7 pounds so 1.5*7 is 10.5
