I've noticed a draught coming through a window recently so took a good look at it.
It's an Everest window fitted perhaps 10 years ago. Looking at the opening part, the seal compresses down to 3mm at the handle side, but on the hinge side the gap varies between 4.5 and 6mm. At 6mm, the frame doesn't touch the seal and air blows around.
So, question to the uPVC window gurus ... are the seals just worn out due to age? Can the hinges be adjusted to narrow the gap and make the seal? I've had a good look but can't see anything. If I strip out the seals and replace, can anyone recommend a seal with a suitable profile and compression properties?
