My Problem
I have no heat downstairs but do have it upstairs and hot water. However, pump still appears to be running as I can hear it switch speeds when I flick the lever on its side (3 speed Grunfoss 15-60)
I have been told that one of my downstairs radiators was sludging (kitchen) in past and that at some point I should clean the system.
I now appear to have no heat to any radiators downstairs - could they all have become sludged to the point of no heat at all?
What have I tried?
I turned off all the upstairs radiators and could get heat to one downstairs radiator but when I tried to run multiple ones I had no joy.
I have put a de sludging agent in the header tank, turned off the inlet and drained enough water from two downstairs drain points to empty the tank. I have been running all afternoon and seen no change to downstairs.
When I drained water from the system it ran reasonably clear (I opened the inlet valve and shut the outlet valve to get the water running through the radiator).
Finally, at times I can get heat down as far as the inlet valve but it doesn't appear to be getting into the radiator.
Your thoughts would be much appreciated.
My Problem
What have I tried?
