Hi
I had the Evohome system working but was getting a boiler relay fault so wanted to set it up again. Problem is, I am unsure about how to bind the cylinder thermostat. I have a hot water cylinder.
I am trying to follow the instructions, but at the end, the hot water is not heating up, despite the relay light coming on. I hope someone can tell me where I am going wrong.
I have:
Relay 1 - Central Heating
Relay 2 - HW
CS92 Transceiver
I go into settings and choose guided setup.
Select Stored hot water configuration and press green tick.
This step binds the hot water sensor, so I 5 second press, then single press. Get binding signal was received OK.
Select 2 two port or three post valves.
Now need to bind the HOW WATER VALVE. This is relay 2 (above), correct? I do that and get the signal received message.
Now asks to bind the HEATING VALVE. This is relay 1 (above), correct? I do that and get the signal received message.
So is that all correct so far?
If I now go into DEVICES, under boiler control I have NONE. Do I now need to bind Relay 1 again to the boiler control? Should this be done before the HW or doesn't matter?
Any help really appreciated. My heating is working but water is not. Thanks.
I have:
Relay 2 - HW
CS92 Transceiver
