So T- Off from the 22mm pipe from the boiler is better than messing with manifolds?
I was talking to someone else I know, he got microbore too and in his extension he went to 15mm but didn't know how as plumber did it.
so if I, T- off from before the manifold, and need 2 radiators upstairs/ 2 downstairs then I can take off the upstairs airing cupboard and come straight down into the extension to the ground floor with plastic 15mm and run it straight into 4 rad's...
but the only thing I don't understand then is the cirulation cos if if the 15mm pipe T's off before the microbore how will it get round the whole lot plus the exisiting bore???
