Only my opinion but I've never seen foam actually distort a upvc frame so its really up to you.....either way, the glazed unit doesn't want to be squeezed once its in place.
John
Like the last post, wet the gap first only not to much, I used a spray bottle for this, and put your opening sashes in first to stop any compression.
The foam actually uses moisture to assist curing, normally from the atmosphere but in enclosed space requires a we hand...pinenot
John
