I'm planning on making a cupboard door by routing a groove in some pine or larch for the frame around an mdf panel made up of left-over laminate flooring planks. Are differences in expansion coefficient (either thermal or moisture-dependent) between the different materials likely to be a problem? Can I glue the panel into the grooves, or must it be a loose fit?
