Expansion gaps for OSB flooring?
5 Jul 2011
Kent
Hi everyone.
Am installing OSB3 square edge sheets (8' x 4') x 18mm as a subfloor straight onto joists. I am aware you need to leave a 10mm expansion gap around the edges, but I have read a few pages which recommend a 3mm expansion gap between boards.
Not sure I've ever seen this done before. Is it necessary? I gather with plywood sheets, they are cross bonded and so expand and contract less.
3mm should be enough, although Ive done jobs and they have been butted tight together with no issues. 10mm sounds like a lot!
The reality is that osb is likely to be in an unheated warehouse at the suppliers and if its going into a centrally heated house, its likely to shrink rather than expand.
If you are going onto joists over a vented void with no insulation below then there is a chance of some expansion I suppose. If its first floor, then likely to be in a very dry environment.
