Hi all,
We've got a Worcester-Bosch 30CDi combi, it's approx 12 years old. Recently had a plumber out as our boiler was leaking from the RHS, turned out to be a split o-ring in the turbine sensor assembly.
A few days ago we've noticed a very very small leak from the LHS, which can only be a few drips a day, but there is evidence of white/green crud on one of the metal fittings inside the bottom of the boiler. Today, noticed that the pressure gauge was at 3.5 bar, and it's obviously been venting outside - now curiosity got the better of me, and looking right up inside shows a wet patch on the bottom of a black plastic piece where a copper pipe joins.
Took about 2 - 3 litres out of the system via a rad bleed valve, and pressure dropped to 1.5 bar, but the moment the heating started up again and had run for 20-30 mins it was back at 3 bar, and dripping outside.
I presume it is a gas safe engineer/plumber only job to attempt re-pressurising the expansion vessel?
