- Joined
- 2 Nov 2024
- Messages
- 7
- Reaction score
- 0
- Country
The pressure in my CH system has been fluctuating a bit more than usual recently, so thought I'd check the pressure in the expansion vessel. Reading was zero. No water leaking from schrader valve, and "pinging" the side of the vessel sounds hollow, so I'm thinking the diaphragm may be ok.
Thought I'd try to put a bit of air into the system. Note all this was done without draining the system down - I was just trying to look for problems before I got a more accurate pressure reading.
Completely unable to put any air into the system - using two different tyre pumps (one a foot pump, one an electric one) - both just refused to put air in (e.g. electric pump reading went from 0bar to 5bar in 1 second - i.e. it pressurised the tube to the valve, but couldn't put anything into the valve)
I am able to push down on the schrader valve - no air or water comes out (as I say, reads 0bar on two different pressure gauges)
I changed the inside of the valve with a fresh valve internal - no difference.
Do you think the vessel itself needs changing? Or is this what you would expect if the system wasn't drained down? (if you hadn't guessed - this is all new to me - keen to DIY where possible, as it's all a learning experience!)
(FYI, it's an Aquasystem 18L expansion vessel, no service valve, so would need a full drain of the system to replace, I guess?)
