expansion vessel
7 Dec 2009
Shropshire
Hi am I correct in saying if water comes out of the top valve of the expansion vessel when depressed its faulty.
would draining the boiler and re pressure be a waste of time
thanks
Thanks ive spent a fortune on boiler last few weeks new boards ect is there an easy cost effective replacement vessel as its impossible to remove it from the back of boiler I cant afford to replace the boiler at the moment
thanks
You can have an expansion vessel - of the same size - placed into the central heating pipework if you need to...checkout Screwfix 97531 for example. The feed to the existing one is just blanked off.
John :)
thanks
You'd need to take it off the wall but unless your gas safe registered your goosed as would involve "breaking" a gas connection.
Even if there is enough room to remove it from above the boiler you may need to disconnect the flue bend, either way you need a registered installer.
Thanks for the advice I think I shall have to join the gas board scheme and wait a couple of weeks to get it sorted unless I can get someone local to telford who can sort it for a reasonable price :(
dont take this the wrong way, but do you have any experience or are you a plumber? getting gas safe registered just to do this makes no sense.
Hi im not a plumber I am a fitter for various tools not sure what sort of ballpark figure it would cost to have fitted a new vessel
vessel, 50-100 quid depending on boiler
fitting, 1-2 hours labour.
You may not need to take anything off the wall.
If the schrader valve in the original vessel is holding pressure (water or air) when not depressed, you could just leave it in the boiler and ignore it.
If the schrader valve leaks water when not depressed, I am guessing there is a possibility you could consider a metal dust cap with ptfe tape that could withstand up to 3 bar?!
Some boilers offer some access to EV without taking off wall.
Fitting additional vessel is usually straightforward.
